Ordered a bunch of items for the display, salvaged 14" 1024x768 LCD from a laptop, picked up a replacement kit to replace the CCFL in the LCD with LED's and a LVDS cable that should work with the motherboard I have. Likely will require some wiring harness modifications to get all working.
Firmware for the buttons is largely complete and now need to begin building the a PCB to hold the microswiches behind the buttons.
Still need to come up with a plan for a small amplifier to run the speakers.
