- [x] Shortened exhaust duct (gives you a lot more room)
- [x] Install 100-150CFM fan near the outdoors to suck instead of push the air through the pipe.
- Added a coolant temp gauge
- Added some additional outlets and fittings to the back (12V and air assist)
- Found a hose adapter on Amazon the fit the duct slot perfectly
- Added a stylish cabinet handle (Menards) to lift the cover
- [x] Added an air assist nozzle
- Upgrad mirror to the head assembly
- [x] Removed the stock bed
- Installed an adjustable height one (Thingiverse)
- [x] Added an air pump for the smoke assist and a 110v ventilation fan for smoke removal
- Added some 5v and 12v power supplies inside the electronics section to power various accessories
- Added some additional LED lights for better visibility
- [/] Made a cable chain (Thingiverse) to support the air assist hose and a support for the cable chain
- Made a “laser” spot pointer that shows exactly where the beam will hit
