So far I printed 2 of 6 big gear segments, and by tomorrow the missing ones will be finished. The motor mount and the small gear look good. For sideways support I'm using 608ZZ bearings and a small base. A 45-mm long screw holds the gear in place.
I'm thinking about painting the table surface but I'm not sure if it's worth the effort.
- add an index magnet and a hall sensor (design a mount)
- start working on the firmware and wire the motor up
- source lumber for the shelves, work on the shelf design
