After installing the icestorm tools, arachne-pnr, nextpnr and yosys (which all worked out of the box, apart from some more packages to download), I modified some very old blinky verilog code that was originally written for #DIPSY to work with the board at hand. It was mainly just a bunch of pin assignment changes and using a different clock source.
My blinky code consists of two modules:
clockdivider.v
module clockdivider #( parameter bits = 32 )( input clkin, input[bits-1:0] div, output clkout ); reg [bits-1:0] count = 0; always @(posedge clkin) begin if(count == 0) count = div; count = count - {{bits-1{1'b0}},1'b1}; end assign clkout = (div == 1'b0) ? 1'b0 : (div == 1'b1) ? clkin : (count == {bits{1'b0}}); endmodule
This creates a down-counter with given bit count and reload value. When it reaches zero, it reloads the internal counter with the reload value and starts over. I have no idea if this is good code, or if it's even off by one or whatever. But it seems to do the job.
Next is the top-level module that takes an input clock, feeds it into a clockdivider (see above) and outputs the divided clock to an output:
top.v
module top ( output pin_led, input clk_12m ); reg led = 0; SB_IO #( // IO IP instance .PIN_TYPE(6'b011001) // configure as output ) pin_out_driver ( .PACKAGE_PIN(pin_led), // connect to this pin .D_OUT_0(led) // output the state of "led" ); wire clkout; clockdivider #(.bits(28)) div( .clkin(clk_12m), .clkout(clkout), .div(28'd12000000) ); always @(posedge clkout) led = ~led; endmodule
Again, no quality claims here. But - again - it does the job!
My board has a 12 MHz oscillator and an LED connected like so:
top.pcf
set_io clk_12m 21 set_io pin_led 96
With icestorm, synthesis, placie&route and "packing" (I don't know what the correct technical term is) are three command lines:
yosys -p 'synth_ice40 -top top -blif top.blif' top.v clockdivider.v arachne-pnr -d 1k -o top.asc -p top.pcf top.blif icepack top.asc top.bin
Now there's a bin file to be downloaded to the FPGA's config memory. I couldn't figure out how to program my board's flash chip, so this is for SRAM config:
iceprog -S top.bin
I have this dev rule:
/etc/dev/rules.d/53-lattice-ftdi.rules
ATTR{idVendor}=="0403", ATTR{idProduct}=="6010", MODE="660", GROUP="dialout"
quality level: does the job on my laptop.
And I had blinky!
