Launch Party!
A project log for Android Circuit Python Editor
Use a USB OTG cable with Android devices for Serial, REPL, and a basic code editor for use withCircuit Python Boards.
foamyguyfoamyguy • 12/14/2018 at 14:26•1 Comment
The app is now live in the Android Market! If you were wanting to try out this application, but for whatever reason didn't want to download the apk from Github and side load it then today is your lucky day.
You can download it from the play store using this link:  Play Store Link. Or if you have a Barcode Scanner you can scan the QR below to open up the Play Store.
ericalamar887 wrote 06/06/2023 at 16:14 • point
you made a really good application it helped me a lot with my website where i post apk file you can see here  https://pikashowdownload.in
