Pretty much what it sounds like...
To decide upon a shape for the hull, I looked ships with displacement hulls and merged the elements from various hull types into something I thought would work well. I also decided that the ship's length overall would be about 1 meter. I drafted a scale drawing of the hull's profile from the side and from above, which I used as a guide when building the hull itself. I built the hull by laying fiberglass resin (which I bought from Home Depot) over fiberglass fabric, all of which was draped over a form. I made the form by gluing a heap of 2x4s together in a VERY rough hull shape. I then my 4.5" grinder to carve my wood block into a hull shape. I patched large holes with wall putty so the shape was generally smooth.
