I figured out that i could set a mode by having 2 run modes for the ATtiny85
mode 1: set mode - plays each type of LED blinking patterns, if you want that to be the only one displayed, turn it off when you see it displaying.
Mode 2: display mode - will display the last one which was demoed in a loop, only displaying that one until shutdown again, where it goes into the set mode.
for mode 1 LED 7 will blink before anything else, letting you know it is in set mode.
for mode 2 LED 8 will blink before anything else, letting you know it is in display mode
ON the House those LEDs are the 2 that are over the garage, LED 8 is the left LED and LED 7 is the right LED.
thelogicofpi
Jens Hauke
Brenda Armour
Grayson Schlichting
Do you plan to share the files and code for this ornament ?
