I'm uploading the cfg and scripts I use to reset the lerdge board. THe paths on these are probably all wrong, but it should make your life a little easier if you're hacking.
A project log for Lerdge 3d Printer Mainboard Hacking
Breaking the encryption on the Lerdge series mainboards so I can try porting Marlin 2.0 to it.
