I'm adding MAJ3, AXO1 as well as some AX1x gates. The definition of the guide is not consistent with the naming so beware ! AX1 should be (A and B) xor C but the manual says it is AX1C. This should be checked with the actual tools so until then, put warnings everywhere...
Give me some time to update, check and upload the new archive...
I just confirmed that the manual definition matches with the generated bitstream. I dumped the EDIF of some test code and collected the following equations :
AX1E "!((A & B) ^ C)" AX1D "!((!A & !B) ^ C)" AX1C "(A & B) ^ C" AX1B "(!A & !B) ^ C" AX1A "!((!A & B) ^ C)" AX1 "(!A & B) ^ C"
So I must update the INC8 code...
