#include <SoftwareSerial.h>
SoftwareSerial mySerial(12, 13); // RX, TX
#include <ESP8266WiFi.h> //https://github.com/esp8266/Arduino
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include "WiFiManager.h" //https://github.com/tzapu/WiFiManager
int count=0,i,m,j,k;
int t,t1,t2,t3;
int outputpin= A0;//ds18b20
//////////////////////////////////////// ALL DECLARATIONS for CLOUD //////////////////////////////
const char* host = "api.thingsio.ai"; // OR host = devapi2.thethingscloud.com
const char* post_url = "/devices/deviceData"; // OR /api/v2/thingscloud2/_table/data_ac
const char* time_server = "baas.thethingscloud.com"; //this is to convert timestamp
const int httpPort = 80;
char timestamp[10];
WiFiClient client;
void configModeCallback (WiFiManager *myWiFiManager) { Serial.println("Entered config mode"); //*-*-*-*-*-*-*-*-*-*-*-*-*-*if control enters this function then net is not connected Serial.println(WiFi.softAPIP()); // "WiFi.softAPIP() is for AP" , "WiFi.localIP() is for STA", Serial.println(myWiFiManager->getConfigPortalSSID()); //if you used auto generated SSID, print it
/////////////////////////////////////// TIMESTAMP CALCULATION function///////////////////////////////////////
int GiveMeTimestamp()
{ unsigned long timeout = millis();
while (client.available() == 0) { if (millis() - timeout > 50000) { client.stop(); return 0; } }
while (client.available()) { String line = client.readStringUntil('\r'); //indexOf() is a funtion to search for smthng , it returns -1 if not found int pos = line.indexOf("\"timestamp\""); //search for "\"timestamp\"" from beginning of response got and copy all data after that , it'll be your timestamp if (pos >= 0) { int j = 0; for(j=0;j<10;j++) { timestamp[j] = line[pos + 12 + j]; } } }
void setup() { Serial.begin(115200); //(19200,SERIAL_8E1) - data size = 8 bits , parity = Even , stop bit = 1bit mySerial.begin(115200); WiFiManager wifiManager; wifiManager.setAPCallback(configModeCallback); if(!wifiManager.autoConnect("xxxxxxxxxxxxxx","xxxxxxxxxx")) //you have to change //wifiManager.autoConnect("AP-NAME", "AP-PASSWORD"); (OR) wifiManager.autoConnect("AP-NAME"); only ID no password (OR) wifiManager.autoConnect(); this will generate a ID by itself { Serial.println("failed to connect and hit timeout"); //control comes here after long time of creating Access point "NodeMCU" by NodeMCU and still it has not connected //reset and try again, or maybe put it to deep sleep ESP.reset(); delay(1000); } //if you come here you have connected to the WiFi Serial.println("connected..."); }
void loop() { int analogValue = analogRead(outputpin);
{ /////////////////////////////////////// SEND THE QUERY AND RECEIVE THE RESPONSE///////////////////////
t1=(analogValue/1024.0) *5000; Serial.print("temp: "); Serial.println(t1);
t2=(t1/10); Serial.print("celc: "); Serial.println(t2);
t3=((t2 * 9)/5 + 32); Serial.print("fhrn: "); Serial.println(t3); //break;
Serial.print("connecting to "); Serial.println(host); //defined upside :- host = devapi2.thethingscloud.com or 139.59.26.117
///////////////////////////////////// TIMESTAMP CODE SNIPPET /////////////////////////
Serial.println("inside get timestamp\n"); if (!client.connect(time_server, httpPort)) { return; //*-*-*-*-*-*-*-*-*-* }
client.println("GET /api/timestamp HTTP/1.1"); //Whats this part doing, i didnt get client.println("Host: baas.thethingscloud.com"); client.println("Cache-Control: no-cache"); client.println("Postman-Token: ea3c18c6-09ba-d049-ccf3-369a22a284b8"); client.println();
GiveMeTimestamp(); //it'll call the function which will get the timestamp response from the server
Serial.println("timestamp receieved");
Serial.println(timestamp);
Pradeeplogu
