Open/close/state/car inside or not/humidity/temperature/doors moving
Garage_Door_V1.0.ino_share.inoino - 25.65 kB - 11/17/2019 at 12:53 |
SCH_Garage_Door_V1.1.pdfFutur version, now modified some IO from V1.0 to this schematic manuallyAdobe Portable Document Format - 111.92 kB - 07/11/2019 at 19:38 |
IMG_20190711_213310.jpgJPEG Image - 3.46 MB - 07/11/2019 at 19:35 |
IMG_20190711_213252.jpgJPEG Image - 3.71 MB - 07/11/2019 at 19:35 |
IMG_20190711_213302.jpgJPEG Image - 2.95 MB - 07/11/2019 at 19:35 |
Need to change encoder pining on my schematic, I will use powered encoder instead of just switch encoder, to avoid bounce from encoder.
Need to change from a 230-3.3V to a 230-5V because encoderLPD3806 is 5-24V powered
What kind of ambient temperature range does your ESP32 experience? My garage here in Canada gets down to -25C on occasion, so I am reluctant to put an ESP32 out there. What's your experience? Cheers,
Actually in Switzerland I have around 10-15° with an outdoor temperature between -5°C and 10°C
I don't know if my sensor and the ESP is able to work well at lower temperature
Take a look to my project: https://github.com/nayarsystems/virkey
have you pictures or schematic of your project ?
Mine looks a bit more complete
have a look on my project https://garagedoorrepairvoorhees.com/
