1 month after ordering, parts started arriving from China, manely top of the line RUIDENG DPS5005 50V 5A's with communication support.
What Dave couldn't do was done.
Revealing it was 2 boards soldered together with 2 pin headers & a display on a 3rd board, itself soldered by a 1 pin header. Its only attachment to an enclosure was the liner. The standoffs were loose fitting.
16 pins with conformal coatings ensnared the 2 boards.
So there would be no replacing the display or the buttons with any ease. It was already decided that the bluetooth & USB support wasn't worth it. That was only ordered in case someone needed to test a voltage ramp. At least there's alternative firmware.
