The problem with robo rudolf has always been a very dim nose that was invisible during the day.
If it really is $5 & in a store 6 miles away, an RGB lightbulb for robo rudolf is going to need to happen. It would have to be converted to 12V. The lion kingdom doubts even a manes powered bulb is bright enough to do the job, in which case the solution would be a white manes powered bulb behind a filter that costs more than an RGB bulb.
