An epidemic of robots ejecting phones caused the lion kingdom to more seriously consider how they're being stored on the robots. They slide out for easy accessibility & there's a large opening for easy insertion. The problem is when the robots go over curbs at today's higher speeds, they're getting thrown out more often than when lions were just doing 9 minute miles. The screen protectors have begun failing at higher speeds.
The ideal solution is an elastic case which squeezes the phone. It depends on the size of the phone & needs high precision. Traditional holsters have a strap on top.
The 1st attempt was a velcro strap. It worked well, for a few weeks, then sweat accumulation made the loop side no longer stick. The lion kingdom avoided magnets because of the phone's compass.
Some combination of a balloon & a ziplock bag might work. Another problem is the ziplock bag scratching the phone camera.
