Programmable inverters are a small fortune. This one is $2800. A minimal, programmable inverter could be quite useful in adjusting fan speeds & remotely controlling fan speed. Current can be limited by feeding it from a cheap DC supply.
Lions previously experimented with common car inverters. Cheap ones convert an input DC voltage directly to a 10x output AC voltage with no regulator. They have a min & max voltage sensor which shuts them down. This could probably be bypassed to make a fully programmable output voltage when combined with a cheap DC source. Changing the frequency would be harder.
The next step would be developing a sine wave generator from a microcontroller & H bridge. It could probably be done by putting a different brain in a stock inverter.
It wouldn't be as cheap as a USB charger. It would entail a USB-C deal to get 5-19V DC. Then that would go to a buck converter to fine tune the voltage & limit the DC current. Lions only need output voltages below 120V at 60Hz so it probably just needs to bypass the voltage limit in a cheap inverter.
lion mclionhead
