"8-bit tribute" (2017)
Pixel art of the famous sprite of the Sonic The Hedgehog for the 8-bit sega consoles. This artwork recreates musically the Green Hill stage using the famous SN76489 chip (3 square waved voices and 1 noise voice) used in the SEGA Master System, Game Gear and Megadrive/Genesis.
This interactive artwork can be controlled with a IR distance sensor and 3 different LED colors guide the viewer through Green Hill trying to get the rings, the chaos emerald and finally arriving successfully at the end of the stage.
"8-bit Tribute" - working with pixels
![](https://cdn.hackaday.io/images/8214811546857059858.jpg)
![](https://cdn.hackaday.io/images/7547181546857215257.jpg)
![](https://cdn.hackaday.io/images/1962751546857216724.jpg)
