12/17/2018
During our three hours in lab, we got a full signal coming out of the circuit. Some of the issues we solved today were getting enough voltage to our op-amps to power them, getting a signal out of the end of the circuit, and rewiring our op-amps with proper resistors. We still need to get the signal to the right amplitude and voltage, potentially add a switch, make sure diodes are in the right place, and attach jacks for testing with a true audio signal. Our connections are quite fragile so we might not end up putting it in an actual project box.
Jonathan and Daniel
