Yak Shaving - aka infrastructure work - aka Erebor
A project log for Home environment monitor
Yet another wireless network of environmental sensors in a home
tundraTundra 02/15/2019 at 12:140 Comments
In order to get OTA updates to work for Dwalin v2 (ESP32 based) and Ori (ESP8266) in a secure manner, an https server needs to be available somewhere. In order to reduce dependencies on network infrastructure, I want this to be a server in the house. For development so far I've been running a copy of "Ubuntu under Windows" from the Microsoft store on my development/gaming machine. Unfortunately this isn't really the same as a VM of Ubuntu - it's more of "part of the userspace but not the kernel and so not quite all of what you are used to" situation. I've been using a mix of Cygwin, MSYS32 and Microsoft's Ubuntu on the Windows machine for a while and none of them are really like just using an Ubuntu machine so I decided this is the time just get a dedicated machine.
So I picked up a refurbished HP Elite 8300 SFF off Amazon (I'm guessing these are from 'off lease returns' from businesses) and built that with a full install of Ubuntu 18.10. Named machine erebor.
Arduino IDE installed on erebor
XPRA on that gives me a nice desktop using RDP from my Windows machine.
I want to use a Let's Encrypt certificate (rather than just a self-signed one) for securing the OTA - however because I'm at home behind Comcast NAT, I can't use the http-01 authentication mechanism - I'll need to use dns-01. That in turn means I needed to move my nameserver from my registrar (namecheap) over to one that plays nicely with available tools to script updates to TXT records (Hurricane Electric).
I want to be able to reach Erebor from the outside in some way, so I set up an OpenVPN tunnel to each of the two cloud VMs (one on AWS and one on Azure) that I have - so I can reach those from outside and SSH over the OpenVPN tunnel back to Erebor. This is essentially the same mode that things like 'LogMeIn' work but managed by me, not by a company that will decide to eliminate features ona whim (yes, I'm still sore that LogMeIn removed a functional-for-my-purposes HTML5 mode from my paid account with them).
Work yet to do:
Then I will be done with the yak shaving (is one ever really done?) and can get back to setting up firmware on Dwalin and Ori.
