I measured the currents of the consumption of the BMS itself.
The results are below.
Mode | Current consumption |
The load is not connected, the LED on the board is not on. | 70 uA, and every five seconds 150..200 uA |
The load is not connected, the LED on the board is not on, BMS connected to PC through UART | 100 uA, and every five seconds 200 uA |
LED on the board is on | 18 mA |
