The first version was laser printed and cut by hand, second run real cards with curved corners!
![](https://cdn.hackaday.io/images/522691546909141994.png)
Picked out some cards to correct / change during play tests. These will be corrected in Illustrator before the next print.
We gave the black cards an inverted back color to tell the two piles apart.
![](https://cdn.hackaday.io/images/4553571546909155935.png)
In finalizing the directions, originally there wasn't a discard pile. We tried it during one of the games and not recycling the cards constantly seemed to work a bit better.
