I went though the design and found a few flaws. One of them being the power supply did not come with a dimmable feature, so I selected one that did off of Mouser. As it is a little closer to the exact rating I needed, it happen to be a bit cheaper as well. Next I need to go and order the LED, power supply and fan off of Mouser and then head to the local electronics store to see if I can find a heat sink that will work in the case. Unfortunately the case is filling up pretty fast, though I would still like to see if I can squeeze a Raspberry Pi into it.
Below is a full change list.
Completed:
- Design fins for intake and exhaust air vents
- Added rocker switch for main power
- Added 3pin AC socket and fuse assembly
- Changed out original spec power supply to one with a dimming feature (modeled dimensions in case)
- Designed threaded dual goose neck adapter part
- All internal components are in place
Apollo
