Imagine a system. wherein a controllable amount of fuel turns a shaft. Two gear-settings can be chosen, ideally for the least fuel-consumption, based on a varying load.
Is there some sort of crossover-point where, for a specific load, the two gear-settings require the same amount of fuel to result in the same speed at the load?
Eric Hertz
