Getting Started.
A project log for Hell-Eedee Cube.
A simple ESP32 3x3 LED Cube that can supports pattern uploads via serial.
taiwoTaiwo • 12/20/2018 at 07:45•0 Comments
This is my first LED cube. It was meant to be a days build but eventually wasn't. I gathered some LEDs I had lying around and made the structure. It was not particularly the most symmetrical but was quite sturdy. I made use of some cardboard to keep the LEDs in place and soldered.
After Soldering
