The wiring managed to fit. The power switch still needs to interrupt the battery connector. The LVD cable is right where a high traffic area is for the battery door. The jetson has a 12V connector even though it's supposed to get 5V. The big HDMI cable managed to fit despite some discomfort. That needs a 1ft flex cable. The back panel manages to contain everything if it flops around. Ideally, the LCD panel wouldn't be supporting anything. A few things needed to be taped to the LCD panel anyway.
