While the standard ESPAsyncWebServer does work on the ESP32, the author does not support the Arduino IDE for it's use, preferring PlatformIO. I want to stay with the ugly beast because it makes the code accessible to a wider range of people (Ok, really I just don't want to learn Yet. Another. IDE). Specifically, the the examples for web servers do not work in the Arduino IDE. However, this page provides a series of examples (See "Related Posts") which document how to make it work.
https://techtutorialsx.com/2018/08/14/esp32-async-http-web-server-websockets-introduction/
e.g. a simple web server via access point:
#include "WiFi.h"
#include "ESPAsyncWebServer.h"
const char *ssid = "MyESP32AP";
const char *password = "testpassword";
AsyncWebServer server(80);
void setup(){
Serial.begin(115200);
WiFi.softAP(ssid, password);
Serial.println();
Serial.print("IP address: ");
Serial.println(WiFi.softAPIP());
server.on("/hello", HTTP_GET, [](AsyncWebServerRequest *request){
request->send(200, "text/plain", "Hello World");
server.begin();
void loop(){}I'm assuming the Async Web Server is still a better option than the built in web server which requires polling (VERY unstable if you do anything of note in the main loop). Please let me know if you have a better option.
I did not try yet but it is very much possible to use ESPAsyncWebServer in Arduino.
https://github.com/penfold42/ESPixelBoard
This project used the lib and is built in Arduino IDE.
So what about the people out there who just have the Arduino IDE and ESP board support files? Can I easily move the code I write in Platform IO back into the Arduino IDE for them? I don't want to put a barrier in front of people who want to just load the code and maybe tweak a few settings. This is my major concern because the incompatibility is already obvious with the example code from the Async Web server library.
I agree with you. But I highly recommend to try PlatformIO. First of all, it's a real IDE, and you can navigate with Ctrl+click through classes. And then I find it much better to keep your dependencies, since they have a piolibdeps per project (No more libraries in 3 different folders like Arduino that drives me crazy).
And it's not so difficult to get to use it, took me about 1/ 2 hours to get started and compile something.
Will try this when I have some time at home. For sure there is a way to make it work in Arduino if you can get the dependencies right.
I second that. It's actually more of a plugin to Atom or VSCode, which are capable IDEs in their own rite, and are good for all sorts of things. I use VSCode with PlatformIO.
And, because PlatformIO can use Arduino libraries and seamlessly integrates with everything Arduino does, it's better than the actual Arduino IDE. Also a kind of intermediate step to using not-Arduino (and with it, better memory / sleep / power management and all sorts of power options, if you want them).
It really is what I recommend everyone use for Arduino development.
Is it fairly easy to publish libraries for PlatformIO? It definitely sounds useful, and maybe I could use that to make my Lasertag project easier to hack, but only if homebrew libraries are easy to add ^^
I'm working with the raw ESP IDF and Eclipse right now, which, although surprisingly comfortable and well documented, I can imagine might be a bit of a hassle for others to install ^^'
