BLDC Static torque Test bench
A project log for Self standing balancing robot
nRF52 mesh of motion sensors, Gazebo for physics simulation, BLDC motors simulation and control, CAD with Fusion 360. Fully Open source.
wassimWassim • 01/03/2019 at 11:37•0 Comments
Objective
PC Gui repo : https://github.com/HomeSmartMesh/raspi
firmware repo : https://github.com/nRFMesh/nRF52_Mesh/tree/master/applications/nrf52832_rovarm
Run the web app and the python serial to mqtt gateway
start python py_rf_serial/cli.py
start live-server web_plot
 Web gui :
Monitor MQTT messages
pi@rfserv:~ $ sub 'jNodes/75/#' -t 'Nodes/75/#' -v | ts
Motor under test
Torque measure
The photo was taken without pressure on the motor, so the 8.9 grams pointed out are not relevant, see results for measures summary
Power
a current limit is set and when the measure is performed, it is simply checked if the current limit is reached by checking if the voltage drops or not.
Results
only direct pio permanent enable is shown, the pwm sine control is excluded for the moment
ESCCoil4 cm measure1 cm conversionNm
7.2 V3.8 V 310 mA75 g300 g.cm0.029
Conclusions
TODO
Open points
