This is a dense little board. It has as the standard bits a floppy controller needs like the WD2793A which is the goto chip. The very interesting part is that this board has RAM, ROM aaaaaand a full 8088 x86 CPU.
The 8088 is another one of those weird 32 bit processors with only an 8 bit bus. Makes me wonder if this board all by itself can be turned into an SBC. Heck, with more ram maybe it could run DOS all by itself?
