Hackaday.io Hackaday.io
Sign up Log in
Spheron
An omni-directional autonomous spherical rolling robot.
varshith-solipuramVarshith Solipuram
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
201 followers
  • Description
  • Details
  • Files 2
    • View all
  • Components 13
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
283
0
201
0
Team (1)
  • varshith-solipuramVarshith Solipuram
Join this project's team
hardware
shelved project
Related lists
todo
g
This project was created on 12/30/2018 and last updated 7 years ago.
Description
Inspired by BB-8 from Star Wars, this was my attempt to build an autonomous spherical rolling robot.
Simply, a drive unit with two diametrically opposite motors is freely suspended inside a spherical casing and an obstacle avoidance unit on the outside of the casing is coupled to the internal unit via Neodymium magnets. Two ultrasonic ranging sensors mounted at 45° to the tangent will detect obstacles and communicate to the unit inside via a 433MHz radio.
Details
Files
Spheron_1_nano.ino
ino - 2.36 kB - 01/06/2019 at 04:30
Download
Spheron_1_Uno.ino
ino - 3.25 kB - 01/06/2019 at 04:30
Download
Components
  • 2 × Arduino For the drive unit and the sensor unit.
  • 1 × Voltage regulator
  • 1 × Neodymium Magnets
  • 1 × A spherical casing with a smooth outer surface.
  • 2 × Ultra-Sonic ranging sensors
View all 13 components
Log In/Sign up to comment
Sign up with Github
OR
Building quadruped robot
Project Owner Contributor
Hobby servos quadruped robot Build
oilspigotOilSpigot
I built a Hybrid Delta Robot using Arduino & Servo motors. Delta robots are widely used in factories for high-speed pick and place operation
DIY Industrial Pick-And-Place Robot | Delta Robot
robotics-everydayRobotics Everyday
My most complex project so far - an adult size humanoid robot.
Humanoid robot
malte-ahlersMalte Ahlers
A plattform to experiment with an omnidirectional drive
omni wheel mobile robot
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Spheron", please tell us the reason.
Send message
Remove Member
