Well to fit in Pi Zero into that case, some LEDS need to go.
As well as the switch. So I unsoldered stuff. Unfortunatly some through hole contacts fell out. Thank god, they weren't critical for the project. Actually it was even useful, since i could use the holes to put the wires for the USB data lines.
