The H-bridge is made from 4 NPN transistors, 2 PNP transistors, and a few resistors.
![](https://cdn.hackaday.io/images/6957471546796862773.png)
I tried to preserve some aspects of the "H" when soldering the components together. The flyback diodes were also from Dad's collection of recycled components, although I didn't show these in the build log.
![](https://cdn.hackaday.io/images/173311546796952590.jpg)
The two verticals wires join the collectors of the NPNs to the collectors of the PNPs. This is where the DC motor will be soldered in the final assembly. I couldn't find the exact resistor value as in the prototype, so I've used resistors in series and resistors in parallel where needed. I do not expect this circuit to perform optimally.
