Electronics
Tested the photo diode sensors on Version 15 and was not seeing a high enough voltage for the ESP8266 to get the high input. Decided to run the the resistor before the sensor instead of after. Breadboarding it showed promise and so I redid the board. I also had the wrong pitch on the motor connectors so I changed it from 1.25 pitch to 1.5 mm pitch. OSH Park set a notice that they are shipping so I need to get the rest of the changes implemented.
Acrylic laser cut parts
Our laser seems to be losing a little steam. Unfortunately everything was dialed in for 10mm/s and 80%. I need to find the new sweet spot. The areas of poor fit from V15 that I will fix and release a new dxf are as follows:
1) Shaft fit for the motor gear and space was too tight. Add a 0.1 negative sew compensation to see if it helps.
2) Make the board holder z height line to line instead of the 0.3mm clearance.
Lastly, I still have not figured out how to manage the laser cut files well. I like to modify in Fusion 360 because the push pull feature is cool, even if there is no design history. However, they can not output a full assembly drawing to a DXF. It can output an individual sketch in DXF but I want to keep the relative spacing for he assembly.
So the workflow is to make the adjustments in Fusion and then expect the Step file. Import it to Onshape, make a drawing and then export the DXF. Here is the link.
Grommets
The tatoo grommets I used for feet are awesome. I tried to replace the drive gear clip with them and it seams to be working very well. This will be one of the main none electronics parts.
or Allexpress
The new axle/gear holders are working great. We just reverted our Prusa MK2.5S to direct drive so I hope the holes do not get filed in like last time. The shape is perfect though so I hope I the print better.
