This was the first step in the project. A single microphone array was used to calculate the angle of arrival of sound waves every quarter second for five seconds.
Alsa programming based on https://www.linuxjournal.com/article/6735
Code:
#define ALSA_PCM_NEW_HW_PARAMS_API #include <alsa/asoundlib.h> #include <stdio.h> #include <math.h> #include <complex.h> #include <fftw3.h>
int main(int argc, const char* argv[]) { /* FFTW Setup */ int num_samples = 250 * 48; //0.25 second * period size (2 bytes/sample) double *channel_1 = (double*) malloc(sizeof(double) * num_samples); memset(channel_1, 0, sizeof(double) * num_samples); double *channel_2 = (double*) malloc(sizeof(double) * num_samples); memset(channel_2, 0, sizeof(double) * num_samples);
int nComplex = (num_samples / 2) + 1; fftw_complex *channel_1_out = (fftw_complex *) fftw_malloc(sizeof(fftw_complex) * nComplex); memset(channel_1_out, 0, sizeof(fftw_complex) * nComplex); fftw_complex *channel_2_out = (fftw_complex *) fftw_malloc(sizeof(fftw_complex) * nComplex); memset(channel_2_out, 0, sizeof(fftw_complex) * nComplex);
fftw_plan pa = fftw_plan_dft_r2c_1d(num_samples, channel_1, channel_1_out, FFTW_ESTIMATE); fftw_plan pb = fftw_plan_dft_r2c_1d(num_samples, channel_2, channel_2_out, FFTW_ESTIMATE);
int i = 0; fftw_complex *multiplication_result = (fftw_complex *) fftw_malloc(sizeof(fftw_complex) * num_samples); memset(multiplication_result, 0, sizeof(fftw_complex) * (num_samples));
fftw_complex *out = (fftw_complex *) fftw_malloc(sizeof(fftw_complex) * num_samples); memset(out, 0, sizeof(fftw_complex) * num_samples);
fftw_plan px = fftw_plan_dft_1d(num_samples, multiplication_result, out, FFTW_BACKWARD, FFTW_ESTIMATE);
/* ALSA Setup */ int rc; int num_channels = 4; snd_pcm_t *handle; rc = snd_pcm_open(&handle, "plughw:1,0", SND_PCM_STREAM_CAPTURE, 0);
if (rc < 0) { fprintf(stderr, "unable to open pcm device: %s\n", snd_strerror(rc)); exit(1); }
snd_pcm_hw_params_t *params; snd_pcm_hw_params_alloca(¶ms); snd_pcm_hw_params_any(handle, params); /* Interleaved mode */ snd_pcm_hw_params_set_access(handle, params, SND_PCM_ACCESS_RW_INTERLEAVED); /* Singed 16-bit little-endian format */ snd_pcm_hw_params_set_format(handle, params, SND_PCM_FORMAT_S16_LE); /* Two channels */ snd_pcm_hw_params_set_channels(handle, params, num_channels); /* 48000 bits/second sample rate */ int dir = 0; unsigned int sampleRate = 48000; snd_pcm_hw_params_set_rate_near(handle, params, &sampleRate, &dir); printf("Chosen approximate set rate from snd_pcm_hw_params_set_rate_near(): %u\n", sampleRate);
/* Set period size to 12000 frames, each frame is 1ms, we want 0.25 second/ */ snd_pcm_uframes_t frames = 250 * 48; snd_pcm_hw_params_set_period_size_near(handle, params, &frames, &dir); printf("Chosen approximate target period size from snd_pcm_hw_params_set_period_size_near(): %lu\n", frames);
/* Write parameters to driver */ rc = snd_pcm_hw_params(handle, params); if (rc < 0) { fprintf(stderr, "unable to set hw parameters: %s\n", snd_strerror(rc)); exit(1); } /* Use a buffer large enough to hold 1 period */ snd_pcm_hw_params_get_period_size(params, &frames, &dir); printf("Returned approximate period size in frames from snd_pcm_hw_params_get_period_size(): %lu\n", frames); int size = frames * 2 * num_channels; // 2 bytes/sample * number of channels printf("Size of buffer: %d\n", size); char *buffer = (char *) malloc(size);
/* We want to loop for 5 seconds */ unsigned int val = -1; snd_pcm_hw_params_get_period_time(params, &val, &dir); printf("Returned approximate period duration in microseconds from snd_pcm_hw_params_get_period_time(): %u\n", val);
long loops = 5000000 / val; printf("Number of loops to be run: %ld\n", loops);
int fd = open("stream3.raw", O_CREAT | O_RDWR | O_TRUNC, S_IRUSR | S_IWUSR); printf("fd: %d\n", fd); if (fd == -1) { fprintf(stderr, "Error number when opening fd: %d\n", errno); return -1; } int fd2 = open("stream3_2ch.raw", O_CREAT | O_RDWR | O_TRUNC, S_IRUSR | S_IWUSR); printf("fd2: %d\n", fd2); if (fd2 == -1) { fprintf(stderr, "Error number when opening fd2: %d\n", errno); }
while (loops > 0) { loops--; rc = snd_pcm_readi(handle, buffer, frames);
if (rc == -EPIPE) { /* EPIPE means overrun */ fprintf(stderr, "overrun occurred\n"); snd_pcm_prepare(handle); } else if (rc == -EBADFD) { fprintf(stderr, "PCM is not in the right state\n"); } else if (rc < 0) { fprintf(stderr, "error from read: %s\n", snd_strerror(rc)); } else if (rc != (int) frames) { fprintf(stderr, "short read, read %d frames\n", rc); }
//At this point, buffer contains the frames from all 4 channels //Recall that each frame is a set of (4) samples, one from each channel. //Each sample is 2 bytes, [LSB, MSB] //Our goal here is to get the first channel and the fourth channel. int z = 0; char ch1_ch4_buff[2 * 2 * rc]; // 2 bytes/channel * 2 channels * 48 frames = 192 //size = 48 * num_bytes_per_channel * numchannls = 48 * 2 * 4 = 384 for(z = 0; z < size; z += 8) { char lsb_ch1 = buffer[z]; char msb_ch1 = buffer[z + 1]; char lsb_ch4 = buffer[z + 6]; char msb_ch4 = buffer[z + 7]; ch1_ch4_buff[z / 2] = lsb_ch1; //LSB of channel 1 ch1_ch4_buff[z / 2 + 1] = msb_ch1; //MSB of channel 1 ch1_ch4_buff[z / 2 + 2] = lsb_ch4; //LSB of channel 4; ch1_ch4_buff[z / 2 + 3] = msb_ch4; //MSB of channel 4;
//convert these integer samples to doubles and place them in their arrays int ch1 = (msb_ch1 << 8) + lsb_ch1; double d_ch1 = ch1 * 1.0; channel_1[z / 8] = d_ch1; int ch2 = (msb_ch4 << 8) + lsb_ch4; double d_ch2 = ch2 * 1.0; channel_2[z / 8] = d_ch2; } //now, ch1_ch4_buff[] contains just the frames from channels 1 and 4 z = write(fd2, ch1_ch4_buff, 2 * 2 * rc); rc = write(fd, buffer, size); if (rc != size) { fprintf(stderr, "short write, wrote %d bytes\n", rc); }
//Now that the samples are written to files, let's compute the GCC-PHAT for the previous 0.25 second //1. FFT the 16 bit integer samples for each channel into complex doubles fftw_execute(pa); fftw_execute(pb);
//2. Multiply (element-wise) the two channels together, having taken the complex conjugate of the fourth // Also divide by magnitude at this step, for PHAT weighting for(i = 0; i < nComplex; i++) { fftw_complex mult_result_numerator = channel_1_out[i] * conj(channel_2_out[i]); double mult_result_denominator = cabs(channel_1_out[i]) * cabs(conj(channel_2_out[i])); multiplication_result[i] = mult_result_numerator / mult_result_denominator; }
//3. Apply inverse transform to the product from step 2. fftw_execute(px);
//4. Rotate output array so that center of array corresponds to broadside angle double rotated[num_samples]; for(i = 0; i < num_samples; i++){ fftw_complex to_rotate = out[ (i + nComplex) % (num_samples) ] / num_samples; double abs_to_rotate = cabs(to_rotate); rotated[i] = abs_to_rotate; }
//5. Get argmax from GCC-PHAT double max_amp = 0.0; int max_index = 0; for(i = 0; i < num_samples; i++){ double amp = rotated[i]; if(amp > max_amp) { max_amp = amp; max_index = i; }
/* double amp = cabs(out[i]); if(amp > max_amp) { max_amp = amp; max_index = i; } */ } printf("Max amplitude of GCC-PHAT occurs at: %d\n", max_index); /* double delay = (max_index - (num_samples / 2)) * (1.0/48000); double sin_theta = (delay * 343.3) / 0.06; double theta = asin(sin_theta); printf("delay: %f\n", delay); printf("theta (radians): %f\n", theta); printf("theta (degrees): %f\n", theta * (180 / M_PI)); */
if(max_index > num_samples / 2) { double delay = (max_index - (num_samples / 2)) * (1.0/48000); double sin_theta = ( delay * 343.3 ) / 0.06; double theta = asin(sin_theta); printf("delay: %f\n", delay); printf("theta (radians): %f\n", theta); printf("theta (degrees): %f\n", theta * (180 / M_PI)); } else if(max_index < num_samples / 2) { double delay = ((num_samples / 2) - max_index) * (1.0/48000); double sin_theta = ( delay * 343.3 ) / 0.06; double theta = asin(sin_theta); printf("delay: %f\n", delay * -1); printf("theta (radians): %f\n", theta * -1); printf("theta (degrees): %f\n", (theta * (180 / M_PI)) * -1); } else { printf("delay: %f\n", 0.0); printf("theta (radians): %f\n", 0.0); printf("theta (degrees): %f\n", 0.0);
snd_pcm_drain(handle); snd_pcm_close(handle); free(buffer); close(fd); close(fd2);
free(channel_1); free(channel_2);
fftw_destroy_plan(pa); fftw_destroy_plan(pb); fftw_destroy_plan(px);
fftw_free(channel_1_out); fftw_free(channel_2_out); fftw_free(multiplication_result); fftw_free(out);
return 0; }
