Another failure...
This morning I changed slightly the cutting parameters of the final cut hoping that this will help. I also gave up on using WD-40 hoping that this will avoid jamming the wheels of the Y carriage. I was wrong...
![](https://cdn.hackaday.io/images/1138061562494583821.jpg)
![](https://cdn.hackaday.io/images/2609931562494618878.jpg)
![](https://cdn.hackaday.io/images/3707391562494628097.jpg)
The Y axis keeps jamming. The aluminium chips gets stuck on the linear rails and the wheels adding some unneeded friction in the Y movements.
But hey, I'm a hacker. Let's hack this little beast and see what happens.
![](https://cdn.hackaday.io/images/8489051562494754052.jpg)
![](https://cdn.hackaday.io/images/7680471562494771413.jpg)
![](https://cdn.hackaday.io/images/5155911562494771883.jpg)
![](https://cdn.hackaday.io/images/3203211562494772726.jpg)
![](https://cdn.hackaday.io/images/5842401562494773082.jpg)
Some double-sided tape and cardboard later, here's some nice debris shields for the linear rails. These don't need to be sturdy so cardboard is an excellent choice.
![](https://cdn.hackaday.io/images/9942691562494858830.jpg)
![](https://cdn.hackaday.io/images/6915431562494859231.jpg)
![](https://cdn.hackaday.io/images/8206081562494859541.jpg)
.. and here's the machine ready for another attempt.
Wish me luck!
