Partial assembly.
I finally had some time to go on with the PCB assembly. Turns out the most difficult part (caps) was a breeze, the WS2812B leds... not so much.
Getting ready for the assembly.
Let's start with the hard stuff... RGB leds.
Now it's the Kailh PCB sockets turn. I was worried I couldn't apply the same technique as before, since I never used them. Turns out they're quite easy to solder.
Unfortunately my Arduino Pro Micro is not here yet (the one in the first pic have the header pins soldered in the wrong orientation and I don't trust much my desoldering skills) so I can't finish the build.
I hope they'll arrive soon, I need to know if everything works!
