YamPAD project log 20
A project log for YamPAD - Feature-packed open source macropad
A fully open-source, mechanical, hot-swappable, RGB backlit, QMK powered, OLED screen featuring numpad/macropad.
mattia-dal-benMattia Dal Ben 08/22/2019 at 08:230 Comments
Final assembly...
Finally... we can assemble the YamPAD and complete the project.
Here's all the parts:
Let's start by adding some rubber feets.
Then the threaded inserts. These are actually for plastics but work great for wood too.
And now the easy part: plate, screws and keycaps.
I really like the contrast between the aluminium plate and the brass screws.
You may wonder why all those different switches: I'll use this numpad as a swith tester to convert my collegues at work :D
Did I mention that it works too?
And now I think we can call this project complete.
Time to sum up the project. What would I do differently?
Design wise:
Regarding materials:
Maybe I'll fix a few of these problems in the next iteration, but for now I'm happy with the results :D
Rich text editor
