The input/output of the circuit is working fine. The NX5DV330 is doing fine as well(but no longer manufactured).
two things to consider for the next round. 1/ use very sharp clippers to cut lead otherwise it may damage pcb traces (doh...) 2/ don't confuse TSOP20 package with SOIC20 package (doh...x2).
I'm still undecided on what signal to add with the video one. Currently I'm thinking about a noise source through a filter and some random crap from a microcontroller with a bit of entropy (microphone) sent to the mixer to create luminance bursts.
