Yesterday I started the task of actually making the front plate. Since this requires that I mill on both side of the plate this required yes, you guessed it, two sided milling. Since I have not done that before this was a very exciting experiment. It starts almost like any standard milling.
![](https://cdn.hackaday.io/images/5552741550957793089.jpg)
First I put on the material I am going to cut , but the first plate of material is just a second sacrificial plate. That's because I am going to use wooden dowels to align the oak I am going to cut in so that there is no offset when I turn it around.
![](https://cdn.hackaday.io/images/2119771550958082437.jpg)
I had learnt this dowel technique from a guy at my local makerspace. I have one in each corner outside the piece I am going to cut out of the material. This way the 6mm dowels restricts all the movement horizontally. I first tested (with scrap material) to align it with screws. This proved way be way to unreliable. As the dowels have the same diameter all the way it is a much better candidate.
![](https://cdn.hackaday.io/images/7169511550958576613.jpg)
First side done. Here you can see dowels and screws to restrict movement in all axis.
![](https://cdn.hackaday.io/images/8079681550958758105.jpg)
This was the nerve wracking part. Turning it around and see if it aligned correctly. I had 1 millimeter of margin on each side so precision was key.
![](https://cdn.hackaday.io/images/2447361550958940830.jpg)
It fortunately was within the margins! Next time I will put dowels in the cutouts for the speaker elements so it even more precise.
![](https://cdn.hackaday.io/images/3877671550959096425.jpg)
Temporarily mounted it to the aluminum case with a block of soft wood and a rubber mallet. Looks good!
![](https://cdn.hackaday.io/images/9377181550959238212.jpg)
![](https://cdn.hackaday.io/images/3676221550959262744.jpg)
Mockup with the screws that where available from the makerspace.
![](https://cdn.hackaday.io/images/6265751550959339525.jpg)
