I worked some more on the bracket today that is going to hold the back plate on.
![](https://cdn.hackaday.io/images/4746981551197272072.png)
These back plate holders will be made in aluminum. It is sturdy enough to hold the load and nice material to tap into. This is the screws I am using:
![](https://cdn.hackaday.io/images/8134851551197612280.jpg)
I wanted something golden to make it stand out. These screws are m6 and I intend to tap threads into the brackets. I found this excellent sheet to find out what hole I needed to drill to get the correct thread.
https://littlemachineshop.com/images/gallery/PDF/TapDrillSizes.pdf
as show it states that I need a 5mm hole if the thread pitch is 1mm and 5.25 if the thread pith is 0.75. I used a thread gauge to find the correct pitch.
![](https://cdn.hackaday.io/images/53011551197853072.jpg)
![](https://cdn.hackaday.io/images/216341551197870320.jpg)
As I now know it was 1mm thread pitch I made a 5mm hole. then I found a m6x1.0mm tap and got to work.
![](https://cdn.hackaday.io/images/6636331551198005912.jpg)
![](https://cdn.hackaday.io/images/5427141551198027990.jpg)
It went very smoothly and was no problem using the screw.
![](https://cdn.hackaday.io/images/6543921551198148932.jpg)
The more I test such things the less errors I make during the machining. Hopefully.
