This project really needs some filtering of the audio as well as being sped up a bit to have the "computer sounds" a little more "authentic".
But I don't have access to the original hardware and today I'm more into doing things the hard way with just transistors like the #KCS tape viewer or even the #Analog Blinken Grid so I guess it would be cool to remake this with regular BJT transistors.
I guess I'll probably need an unijunction transistor for the VCO and a J-FET for analog switch in the sampler, but that's ok - they are still transistors ;-)
matseng
