Started testing the hardware. Need another On/Off-controller since the current model allows only 2 seconds time frame for the feedback from microcontroller and the SAMD21 with Arduino bootloader needs ~2.5 seconds for booting and setting the GPIO to High.
Following initial tests passed (tested with example codes)
- RFM95 module
- I2C RTC (fixed a mistake in routing of I2C. SDA and SCL were swaped :( )
- uSD-card
- LiPo charger
- programming over USB
Next steps:
- order some missing parts (capacitors for the display)
- test display :-)
