Some people asked if I already published the LoRaNicator source code. At the moment I don't have a LoRaNicator specific code. There are just two example codes merged together and modified . The RFM95 example code from Adafruit und the display example code from u8g2 lib.
See Adafruit Tutorial for a transmitter setup.
If you still want to see my actual code, you can find a snippet here
That's it!
For tests with RTC, SD-Card, navigation switch etc, I just used Arduino example codes.
I'm not a programmer and my source code for AVR microcontrollers was always bad. Now, the SAMD21 is completely new for me and I've to figure out a couple of things and have to RTFM ;-)
5Volt-Junkie
