Logging and startup current fixes.
A project log for Minimalist Li-Ion Discharger/Capacity meter.
What you need to grade your scavenged cells for building balanced packs.
masterofnullMasterOfNull 01/30/2019 at 02:500 Comments
I rearranged the start sequence and serial logging so it makes more sense while starting up.
I also eliminated the bug where discharging starts at 100% load.  You can now set the start PWM level.
int Start_PWM = 200; // Starting value for PWM before current control kicks in. 0-255
While I was at it, I attributed the original article in the source.
New source is up.
