Still continuing to cycle the cells a second time. Still all going up in mAh value, save one which went down 30mAh.
10 cells left to do.
Ordered some Li-ion charger PCB and 18650 battery holders from Amazon. Both were 10 for $9, and will let me charge 10 at a time, at 1A. That should give me some more options for cycling cells I'm questioning, without being so darn slow.
<EDIT> Cell charger done. I wish I had done that way sooner... </EDIT>
Also built a cell welder and tested it.
Works well, but you have to be careful to keep the pulse duration short, as shown on my test cell here where I burned through.
