8 watts RGB Led only + lens from led-tech.de
Please comment if you are interested in the design and follow this project.Concrete Lamp refactoring into an ESP-Mesh RGB Lamp with White channel
3 eigth watts RGB + some warm White 5mm leds
A project log for ESP32-MeshKit custom RGB LED Lamps
Use this RGB Leds that are in your garage to build your own Lights. As simple as Leds, Ω and soldiering (To be safe max. 30 mA per GPIO)
