Now you can integrate the power of DepthAI into your custom prototypes and products at the board level because...
We open sourced the carrier boards for the DepthAI System on Module (SoM). So now you can easily take this SoM and integrate it directly into your designs.
Check out our Github here:
https://github.com/luxonis/depthai-hardware
So this covers all the hardware below:
![](https://cdn.hackaday.io/images/9664801587588151238.png)
![](https://cdn.hackaday.io/images/985051587588152117.png)
![](https://cdn.hackaday.io/images/8867781587588154033.png)
![](https://cdn.hackaday.io/images/1279301587588156414.png)
![](https://cdn.hackaday.io/images/8382241587588157995.png)
![](https://cdn.hackaday.io/images/9118551587588158902.png)
