Hackaday.io API library for Arduino
A wrapper library around the Hackaday.io API for network connected Arduinos (ESP8266, ESP32 etc)
I thought it would make a good video to create an API arduino library from scratch and the Hackaday.io API provides the perfect platformThe first goal of the library would be to return project data (number of likes, number of followers etc)
Dan Maloney wrote 02/01/2019 at 19:27 point
I really need to play with the API at some point. I have ideas...
Brian Lough wrote 02/03/2019 at 13:43 point
So far it's a nice API to play with! I'm just implementing the project info endpoint for now so you can display likes and skulls of a project but it should be easily updated if required!
