So a project is hard to test if it doesnt exsist!! So i knocked up a quick board to test how it all works. Its simply an atmega32u4, 24lc512 i2c flash, and a sexy little IPS screen i have been trying to find a use for. I tried to keep it all as compact as possible so it could easily fit on a keyring
Once the boards land i will see if they work, then i will share once its been proven to work :)
moosepr
