I started by setting up the project structure in a similar way satoshinm did. As I've mentioned before, this article by him - making a Rubber Ducky with Blue Pill - helped me a bit.
The project references the libopencm3 repository and provides 2 Makefiles. Top level Makefile fetches the libopencm3, builds it and builds the firmware. Makefile in the src directory only builds the firmware binary.
Before I could actually flash the boards I decided to check the resistors on the USB lines. The Blue Pill boards suffer from a wrong resistor values. The boards I received used 4.7k resistors, while they should be 1.5k. I desoldered them and soldered in ones with the proper values (1.5k).
I started by copying the code from this example. I stripped it from the DFU functionality.
I also changed the clock source to external 8MHz. In libopencm3 that meant going from:
rcc_clock_setup_in_hsi_out_48mhz()
to
rcc_clock_setup_in_hse_8mhz_out_72mhz()
What puzzled me a bit in libopencm3 is that you can stumble on functions that seem to do the same yet are named differently. An example of that would be:
gpio_mode_setup()
and
gpio_set_mode()
If you look into this file though you can find the answer:
/* * Note: The F2 and F4 series have a completely new GPIO peripheral with * different configuration options. Here we implement a different API partly to * more closely match the peripheral capabilities and also to deliberately * break compatibility with old F1 code so there is no confusion with similar * sounding functions that have very different functionality. */
...oh, ok then. That meant that for a STM32F1 the gpio_set_mode() was the way to go.
After that I worked on setting SysTick in such a way that it fired 100 times per second.
systick_set_clocksource(STK_CSR_CLKSOURCE_AHB_DIV8);
// SysTick interrupt every N clock pulses: set reload to N-1
// 72MHz / 8 = 9MHz
// 9000000Hz / 90000 = 100Hz
systick_set_reload(89999);
systick_interrupt_enable();
After plugging the board to the PC it did get recognised. I didn't went too deep into what happens when I plug the board in. I went on to add the I2C functionality so I could poll the Wii Nunchuk controller. Little did I know...
But that's a story for the next episode! Stay tuned!
Michal
