// switch.l1com // Brackets - Hello world! switch // #include (main func) (set int64 1 zero 0) (set int64 1 x 23) (set int64 1 y 42) (set string s 23_str "y = 23") (set string s 42_str "y = 42") (set const-int64 1 23_const 23) (set const-int64 1 42_const 42) (set string s hello_str "Hello world!") (set int64 1 a 0) // print string print_s (hello_str) print_n ((x y *) a =) print_i (a) print_n (switch) (y 23_const ?) print_s (23_str) print_n (break) (y 42_const ?) print_s (42_str) print_n (break) (switchend) exit (zero) (funcend)
This program uses the switch statement. It prints out:
$ l1vm prog/switch -q Hello world! 966 y = 42
