I wrote a benchmark calculating with double float numbers.
The benchmark on my L1VM is close to a native C program doing the same math.
Here is the L1VM benchmark source code:
(main func)
(set int64 1 zero 0)
(set double 1 x 23.0)
(set double 1 y 42.0)
(set double 1 z 7.0)
(set double 1 a 1.0)
(set int64 1 max 80000000Q)
(set int64 1 one 1)
(ASM)
loada zero, 0, I0
loadd x, 0, F1
loadd y, 0, F2
loadd z, 0, F3
loadd a, 0, F4
loadd a, 0, F10
loadd y, 0, F22
loadd x, 0, F20
loada one, 0, I4
loada max, 0, I5
loada one, 0, I6
loadl :jit, I40
loadl :jit_end, I41
// run jit compiler
intr0 253, I40, I41, 0
:loop
// call jit code
intr0 254, I0, 0, 0
// jump to following non-jit code
jmp :next
:jit
addd F10, F20, F10
addd F10, F20, F10
addd F10, F20, F10
addd F10, F20, F10
addd F10, F20, F10
addd F10, F20, F10
addd F10, F20, F10
addd F10, F20, F10
addd F10, F20, F10
addd F10, F20, F10
addd F10, F22, F10
addd F10, F22, F10
addd F10, F22, F10
addd F10, F22, F10
addd F10, F22, F10
addd F10, F20, F10
addd F10, F20, F10
addd F10, F20, F10
addd F10, F20, F10
addd F10, F20, F10
addd F10, F20, F10
addd F10, F20, F10
addd F10, F20, F10
addd F10, F20, F10
addd F10, F20, F10
addd F10, F22, F10
addd F10, F22, F10
addd F10, F22, F10
addd F10, F22, F10
:jit_end
addd F10, F22, F10
// store
:next
intr0 5, F10, 0, 0
intr0 7, 0, 0, 0
addi I4, I6, I4
lseqi I4, I5, I30
jmpi I30, :loop
intr0 5, F10, 0, 0
intr0 7, 0, 0, 0
intr0 255, 0, 0, 0
(ASM_END)
(funcend)
Here is the result of the C program:
$time ./double-test >/dev/null 2>&1
real 1m3,400s
user 1m3,249s
sys 0m0,148s
And my L1VM:
$time vm/l1vm prog/jit-test-double >/dev/null 2>&1 real 1m11,828s user 1m11,704s sys 0m0,120s
So my VM is close to C in that case. :)
